L100 air intake
L100 air intake
Hi all
Just wondering, what are people doing for different air intakes? Im still running the stock one, but would like to replace it with a high flow cone/foam filter at some point, how are people attaching them?
Rhynri
Re: L100 air intake
Post by Rhynri »
I am not familiar with your arrangement, my only advice is that you be sure to use a hanger if your new airfilter is heavier than your stocker, or bad things could happen.
henneberg
Re: L100 air intake
Post by henneberg »
I have installed a K&N SU filter, it gives more response during acceleration,
Re: L100 air intake
Yes, K&N or 2-3 stage foam, anything better than cardboard or paper filters. Incidentally, the Ruggerfields filter was originally fitted up front but was moved to behind the rider (corrugated pipe link) because the sound was less tiresome on the riders ears. Corrugated pipe is not a bad thing either - seems to help it some.
Re: L100 air intake
Thanks for the input guys, will keep an eye out on ebay for air filters that I can make fit :), having the intake right infront of my face is pretty loud!
Re: L100 air intake
Chrome sink drain pipe into the supercharger accumulator. Total cost $.50. It would also accommodate a K&N filter mounted directly onto the pipe and facing forward.
Re: L100 air intake
Many for the suggestions, ended up going with a k&n su filter, its a lot louder, but at higher rpms it sounds great!
Needed a bit of modifications for the screw mounts and the cork gasket, all good otherwise.
Bit more poke too, all good!
old clunker
Re: L100 air intake
Post by old clunker »
Is it a 1 and 1/2" or 1 and 1/4" dia. SU filter that fits the intake? Thanks for further info.
Re: L100 air intake
http://www.knfilters.com/search/product ... od=56-9155
This is the one I have. I managed to use the gaskget it came with but I did need to widen a few holes and cover some holes with glue that wasn't covered by the filter.
