Diesel Single Bobber Build
DieselFly
Re: Diesel Single Bobber Build
Post by DieselFly »
Lots of beer helps :mrgreen:
Rhynri wrote:
coachgeo wrote:
DieselFly wrote:.... Looking at your pictures you may want to install you driven clutch first as your drain tube looks like it will hit where your turbo is mounted....
Assume you mean Drive clutch or Primary Clutch. The terms are confusing. Driven is the Secondary clutch. as in it is "driven" by the primary/drive clutch that is spun via the crank
That's what happens when you let an engineer name something. :P
I tease, of course. Yes the terms are very confusing.
Finished and riding 1975
CB500t Turbo Punsun powered
hardtail.
dieselbikin
Post by dieselbikin »
Here's the bike mentioned previously:
http://www.bikernet.com/pages/The_Notor ... ammer.aspx
1980 Suzuki 550
10 HP Yanclone
94C Comet
radicalnegative1
Post by radicalnegative1 »
Latest development:
http://www.youtube.com/watch?v=Fwfe4LhJDqY
Does everything look ok?
DieselFly
Post by DieselFly »
Looks good so far. Its amazing how much these little turbos whip up the oil. If you can use a piece of copper tube or something like it on your turbo return it will help dump some heat out of the return oil
radicalnegative1 wrote:Latest development:
hardtail.
radicalnegative1
Once I get a driver/driven combo I'll cobble up a more permanent oil return line.
I also did the PCV valve modification described by some guy on YouTube. Pretty straightforward, actually. Everything came out great.
Next is the plenum chamber.
07gtimyfast
Post by 07gtimyfast »
updates!?! Spring semester is almost over!
radicalnegative1
Right.
So the bike has been home in Ohio for all this time, and, unfortunately, I go to school in Alabama. So I haven't been able to work on it except for over breaks.
The good news is that this week is exam week. So after this week, I'll be heading home and get this thing finished.
I'll kick it into gear once I get back. I'll have a full-time job/internship thing, but since I'm living at home, I should have plenty of time to work on it.
radicalnegative1
Here we go - some updates finally.
I can't weld well. I'm working on it, but I don't trust my 'skills' at all. So I've been saving up money and went with a custom frame builder, Cycle One Manufacturing, to build me a frame.
So is that big yellow rimed wheel sitting in front of the bike going to be the back or front tire :?: :mrgreen:
henneberg
Post by henneberg »
Hi, looks nice so far, keep on realizing your ideas :)
radicalnegative1
Just a shot of a rideable mockup I did over thanksgiving. So much more work needs to be done, but progress is being made.
radicalnegative1
More progress!
Adam.Perrault
Post by Adam.Perrault »
Any updates?
