Running problems
Running problems
Hi all
After doing in an injection pump, I have replaced it with a new one and now i have serious running problems.
Firstly, I couldnt rev pas 2000rpm without winding out the fuel bolt at least 4-5 turns. I thought that was a bit odd.
Secondly, and a bigger issue, is that any extended acceleration or high rpm running past 3000rpm, the engine cuts out.
If I wait a bit it comes back to life and misfires heavily, any throttle input makes it cut out again.
It will idle and high idle -2000rpm +, all day without problem.
Completely stuck and really frustrated!
Re: Running problems
? compression leak that manifest it self when engine is really hot such as Head crack or warp? Or head gasket?
? Still not pushing enough full to keep it running under load?
? slightly clogged injector lines?
? fuel lines need replacing?
? Air leak that only manifest itself when under load or when hot?
It does seem air leakish.
I'm going to flush the tank and try some fresh diesel tomorrow to see if it's related.
Right. Today I:
Drained the tank.
Filled with my reliable Veg/Diesel blend (3000 miles + on this blend).
emptied and replaced both fuel filters. (careful not to overtighten on the seals)
Remove the last 5mm of leak off pipe from the injector and re-inserted again.
I now have the bike running again, across the whole rev-range which is nice.
I do have this pretty annoying looping idle, as per this video:
I am not touching the throttle.
https://www.youtube.com/watch?v=E_n3nvb ... blew5IlLFw
Now Im thinking that there is a still an air leak in the system. I have my injector return feed T-ed into the supply pipe, which hasnt caused an issue before, and I can see no holes in the fuel pipe. Any thoughts>
Alex, when you replaced the injection pump, did you re-set the timing (or loose the tappet underneath the pump down into the sump).
I've done it, luckily on a Lombardini 6LD you can remove the sump and retrieve the lost tappet.
I did reset the timing. I also replaced the tappet along with the pump. Luckily I don't think you can drop the tappet into the sump on the l100 (phew!)
I have my timing advanced 5 degrees from where it should be for wvo.
