quad engines
quad engines
Anyone had a look at a diesel quad to see if the engines are any good for bikes?? Also the cvt might be useful?
Re: quad engines
the quads diesel engines are typical 3cyl diesels used in many machines. Briggs/Diahatsu, maybe some Mitsubishi, some Kohler too. Others too. Might be good source for used CVT's in some area's.
Re: quad engines
Brydman knows a bit about the Polaris engine (I think :?: ). It has been mentioned on here. Try having a search about. It's multifuel and if I recall the 2001 onwards are better than what went before.
Re: quad engines
The example below (which is reportedly slated for production) utilizes the Chinese V-twin diesel and a curious "2 speed CVT".
http://www.tonymachinery.com/machinery- ... arket.html
XLerate
Re: quad engines
Post by XLerate »
On either the Kubota or the Briggs/Daihatsu, can't remember which, there was a turbo version & non-turbo version. The turbo had a stonger crank than non-turbos which are well known for crank breakage. Non-turbo is maybe cast, turbo is machined/forged.
Re: quad engines
XLerate wrote:On either the Kubota or the Briggs/Daihatsu, can't remember which, there was a turbo version & non-turbo version. The turbo had a stonger crank than non-turbos which are well known for crank breakage. Non-turbo is maybe cast, turbo is machined/forged.
Heard that about Diahatsu/Briggs. Later years suposedly the Non Turbo was switched to the turbo crank due to the breakage issue. Least that's the story I heard in reference to the ATV.
XLerate
Re: quad engines
Post by XLerate »
Sounds right, Coach, 'cause I was real interested in those engines & did a bunch of research, even joined a tractor related website to dig up more info. Apparently the turbo crank was a good fix. I still like that engine, it's a maybe...
