removing flywheel
arnaud
removing flywheel
Post by arnaud »
Hi.. The flywheel is very attached to the crank..
i reworked the claws of a 3 legged puly so it grasps in the 3 holes in the flywheel of the china diesel.
it is not ideal. you ned a very big one to fit all around.
A trick is to set it on tension and smack it with a big hammer..
But won't that damage the crankshaft??
Dan J
Re: removing flywheel
Post by Dan J »
You could always try Graham's method :mrgreen:
http://tinytim.forumcircle.com/viewtopic.php?t=1356
Dan J wrote:You could always try Graham's method :mrgreen:
ROFL :lol: Thanks for that, hilarious account.
:lol: @ Graham's method ............ PMSL.
I used a little bit of heat on the flywheel whilst putting a considerable amount of preload on the puller. If that fails a small tap on the end of the puller might do the job ~~ Remember you have a ball raced cartridge bearing in the engine on the flywheel side, so don't get to serious with a hammer.
A ;)
arnaud
Post by arnaud »
I took the time to make a device on which you can use the 4 threadholes.. it worked!
Cool 8) Great stuff Arnaud ;) - Big heavy thing isn't it :) !!
A ;)
arnaud wrote:I took the time to make a device on which you can use the 4 threadholes.. it worked!
Pic is worth a thousand words? Video even more 8)
arnaud
Post by arnaud »
Finally, as promised, the self-made tool for china flywheel removal.
