Hi and Help needed please!
guzziray
Post by guzziray »
hi there everybody/ my name is Ray and have been lookin at yr site for long while, and like what I see. I'm currently trying to build a yanmar single project :D Hope to post sum pics soon but i need help with some things, ie throttle linckage and shut down device.
Hope you chaps keep ridin safe.
cheers dudes
guzziray
Re: Hi and Help needed please!
Hi Ray,
the throttle linkage on diesels can be tricky as you're going onto a guvnor arm. You may have to fabricate a bracket to hold the outer cable. Would you believe the one on my bike has been secured by it being held at the oil filler point :?: :D On my bike the lever is at the back of the engine and is not easy to get at :!: I'm hoping the cable doesn't break on me on the way to Germany next week that's for sure :(
Fuel cut off is usually a small button pull or lever thereabouts on the block. You might be lucky and have a place to fit a solenoid coil to switch fuel on and off electrically.
You're pretty local to me and I'm free anytime for the next week and a half. If you want a second opinion send me a time and place and I'll pop over to have a look.
Anorak_ian
Post by Anorak_ian »
Solenoid? A bit fancy that. :)
I use an old choke (carburettor) lever on my handlebars as used on old Brit bikes.
Yeah, ray showed me some pictures of his build at the rally but couldn't see the detail of what is required there.
Maybe try and post some shots Ray?
Here's a shot of my throttle cable holder.
Outer cable holder - Ruggerfield
Hi there Ray - welcome to the forum.
I purchased a solenoid from a auto gas centre, had to have the thing for rego. As soon as rego done the solenoid came off as an electrical fault would leave me stranded.
When I need to shut the engine down i just use the decompression lever or have another little device that drops the throttle lever down to shut off the fuel.
If you have the need, a solenoid can be useful I guess though. Guess it's a topic for the tech section hey :) ?
A ;)
