HOWTO: Timing Advance for Yanmar and Clones
oilburner
Post by oilburner »
I posed the question to a fellow who uses these engines for testing and development in a diesel research lab.
He says:
Grind the top of the pump plunger on an angle so the timing will change according to load and rack setting
It's a simple solution, but unless you understand exactly how to do this, I suggest you buy a handful of plungers.
FYI
Avery
Byrdman
Re: HOWTO: Timing Advance for Yanmar and Clones
Post by Byrdman »
Avery, which Yanmar engine are we talking about?
If it's the L-Series air cooled singles, the timing is determined by the thickenss of the shim stack under the pump.
If we're talking about the TN(A,E,V)-Series liquid cooled inlines, the top of the pump housing can be ground to get additional advance but only very rare instances require this.
I worked as an Applications Engineer with Yanmar America for seven years.
oilburner
Post by oilburner »
Hi Byrdman;
Perhaps you misread the information. This modification provides automatic (dynamic) timing advance - the timing changes according to load and rack setting. As you have stated, the timing on the Yanmar type L engines is static, preset by using shims. The ability to advance/retard timing similar to the advance on spark ignition engines would be a very significant improvement on the Yanmar type engines when operated in the motorcycle application where there are frequent changes in rpm and load.
Hope this is clearer.
Avery
Byrdman
Post by Byrdman »
Avery Frail wrote:Hi Byrdman;
Avery
We must be talking on two different levels. :D
The L-Series injection plunger is a round cylinder and grinding an angle on the top would seem to affect timing only statically.
I guess I don't see how it would chage the timing dynamically?
