If it's the L-Series air cooled singles, the timing is determined by the thickenss of the shim stack under the pump.
If we're talking about the TN(A,E,V)-Series liquid cooled inlines, the top of the pump housing can be ground to get additional advance but only very rare instances require this.
I worked as an Applications Engineer with Yanmar America for seven years.
Hi Byrdman;
Perhaps you misread the information. This modification provides automatic (dynamic) timing advance - the timing changes according to load and rack setting. As you have stated, the timing on the Yanmar type L engines is static, preset by using shims. The ability to advance/retard timing similar to the advance on spark ignition engines would be a very significant improvement on the Yanmar type engines when operated in the motorcycle application where there are frequent changes in rpm and load.
Avery Frail wrote:Hi Byrdman;
Hope this is clearer.
Avery
We must be talking on two different levels.
The L-Series injection plunger is a round cylinder and grinding an angle on the top would seem to affect timing only statically.
I guess I don't see how it would chage the timing dynamically?
