If I found a suitable hub I'd get it wired into a Bullets 19" rim.
Bullet Rear Wheel
Bullet Rear Wheel
Does anyone have any ideas on how to get a 35 or 36 tooth sprocket(wheel) onto a Bullets rear end
johnfireball
Hi Stuart,
As the standard 38 tooth rear sprocket is about as small as the enfield will allow would it not be better to perhaps change the crankshaft sprocket and chain for for a larger one and then purchasing the hitchcocks brake drum with changeable larger sprockets to gear back a tad if necessary.
John
John
Cheers John, yes I reckon I could go from 29T to 31T on the engine cog. Might be the only way I think. Or maybe fit a smaller clutch down the the 56T it has.
Sam, I've heard of the these bikes having disks fitted to the rear. I'm still wondering the right course of action. That lump may have to come out eventually. Even the it will may be hard to put a 19T on the Gearbox. The bike's engine has been turned into a unit construction job outside and then put in. Several key bolts cannot be undone because of the frame
All good fun
All good fun
Hi Guy's
Yeah, changing the front primary or going a 20 on the final drive may be the only option. If you go putting a new wheel on the rear Stuart, you might find that it becomes an issue when you submit the bike for MOT inspections.
I'm only going on what could happen here in OZ "strictest buggers on Earth"
Bye!
Bye!
