Adding sump plug
Adding sump plug
At the moment my sump drain bolt buts up against the gearbox. I change oil using a suction pump, but would like to be able to drain the crud out of the engine every now and then.
There appears to be a blank space on the other side of the engine that looks like it could accomodate a drain bolt.
as shown here:
Can I just drill and tap this, or is it something structural I shouldnt touch.
Re: Adding sump plug
You should be OK as most engines have both sides drilled and tapt. Alternatally if you have enough room for a banjo bolt and a short length of pipe.
hmm, a banjo bolt and pipe sounds interesting, only problem is that it would have to be routed so that it doesnt get snagged etc
Thanks!
A lot of engines sited in dificult places use this method. Normally a short piece of hydralic hose with a blank in the end tied up vertically. Maybe a brake hose from a car or van might do with the right fittings.
I was just thinking of the old brake pipe Nd wondering if that would fit heh.
