At least that's what the speedo states, so lets say 70mph.
I thought I heard a hiss at the rally but I haven't heard it since, but now when I kick the engine over I can feel that the first compression stroke is well easy to kick around when compared to the second. Oh dear.
Anyhow, my question is this, is it worth whipping out the injector to fit a compression tester?
I haven't taken the injectors out before, as I had no need to, and I'm sure that I read somewhere that if you take them out you mess up the settings? Or is it just like a spark plug?
What compression tester or fittings will I need for this engine?
I hope it's not the rings, I don't fancy running it in all over again.
Cheers Ian
