If this is the Pricepartmotorcycles from Gloucester then I will not be buying another thing from him.
He sold me a Bullet clutch said to be in usable condition “I would have no hesitation to reuse this clutch”. I wish he had! It was nailed, worn bearings, worn bearing surface on the clutch centre and basket. In fact the only thing that I could use again was the plates and they needed dressing down with a file (and I already have 2 new sets). Oh almost forgot to say 4 or 5 bearings were missing. He can't even rebuild an old clutch. Glad I didn't buy a bike from him.
Let me tell you about the gearbox he sent me:
Arrived in a cardboard box drenched in stinking black oil, and the main shaft sticking out of the side (bye bye threads, or did he hit it with a hammer) the postman loved that.
Most bolts loose or hand tight, and a loose cracked outer case cos he didn't know how to put the thing back together properly. Main shaft shot, main case missing its brass lay shaft cover and sprocket right off. He even said the sprocket was a 16 tooth!
In his defense he did say that he didn't know what the box was like as he only took it off a working bike, “There is no warranty or guarantee with this item so please satisfy yourselves on the condition before bidding”. What from a photo and a crap description?
So I'll forgive him the parts he couldn't see from the out side: Inner case damaged and both bearings shot.
If you buy a bolt from this bloke make sure to ask him if it has a shaft and a head, but you will probably end up with something from a sex shop!
Of course this may not be the same Pricepartmotorcycles
