So I'm trying to do my math and research before I dive into a diesel repower. I have a blank slate, and I want to do it (mostly) right the first time. I really like the BMW/Moto Guzzi type bikes with in-line 3 cyl 800-1,000cc diesel motors. It just seems to me that the biggest problem with them is getting the gearing to put the motor at a decent cruise RPM matched to a decent speed. I think you're all aware of this issue? Beautiful machines that are limited to 100kph on the rev limit 3600rpm.
This problem is easy to resolve with a laterially mounted crank, primary drive options, and with sprockets for final drive. The range of ratios are virtually unlimited. But I never liked the huge primary covers hanging off the side of American V-Twin bikes. I've seen several 3cyl motors mounted sideways in the frame, but it makes for a very wide creation.
Ideally, I'd like to see a cruise speed of 60mph (~100kph) at 2,000 RPM. I figured out that a 20" (50cm) diameter rear wheel needs to spin at 1,009 to hit 60mph. That means a net 2:1 ratio engine speed to wheel speed.
I also can only assume that someone, somewhere has tried this before, but I can't find anything to verify that assumption.
So here's my conceptual solution:
Sorry about my crude drawings, but I felt like words couldn't fully describe what I'm thinking. I'm sure the scale is all wrong, and I have no idea if there are pullys and belts or Chains and sprockets that will work in this application. I can fabricate all the mounting brackets and stuff that any decent garage head can do, but precise machining and sprocket building is beyond me. I'm guessing that the transmission will sit somewhere in the area of the airbox and battery under the seat of most bikes, but generally available space.
Another problem with finding a shaft drive bike here in the USA is that 90% of them are Japanese bikes, and the transmissions are cast as part of the engine case. Those few European bikes that have detachable gear boxes are too expensive on this side of the pond. I only state this knowing that this forum is predominately UK based. On the other hand, we have a large supply of V-Twin (aka Harley Davidson) and "Chopper" manufacturers of aftermarket stuff for Harley based machines.
Once I give up the idea of being locked to a BMW final drive, the options open up dramatically. I've owned a GL1200 Goldwing, and I'm thinking that it would make a great platform for this kind of contraption (if it will work). It's going to be heavy for sure, and I know from past experience that if you're going to dump a whole bunch of time and money into a project, you might as well end up with something that is comfortable, capable, usable and that you like.
I'd love to know if I'm crazy with this idea? If there's some obviously tall hurdles that I'd face? And if anyone else has successfully built something like this that I can just copy.
Thanks in advance,
-Kevin
