1978 Kawasaki with a Yanmar knockoff
HondaJohn
I posted one or two pics of this bike when I joined this forum, and think its finally time to put up a build thread. Improvements since the summer:
- new wiring harness
- solenoid kill switch
-better clutch lubrication
- new exhaust system
I made the exhaust from pre-bent wiring conduit that I bought from Home Depot. Stripped the zinc and found a guy to weld it up for me. There's no baffles, and its definetley given me more power (and an awesome exhaust note).
http://www.youtube.com/watch?v=r9Zfyyb_Lkg
I also made some adjustments to the clutch, and it now locks up strong enough that I can climb fairly steep hills (very slowly)
Re: 1978 Kawasaki with a Yanmar knockoff
Nice
Did you engine come with a solenoid, or did you fit one later?
HondaJohn
I found a Yanmar supplier in Michigan (http://stores.ebay.com/Auto-Express-Parts) who has them in stock. He pretty much has all the spares for the Chinese Yanmar clones.
- Dougy
I love the style of your bike mate, its very much what I'm going for with mine, Whats the take off like with that HUGE sprocket and whats your top speed ? Also what size is your engine ? All ???'s but I love
- balboa_71
Hondajohn,
Being a single speed drive, it looks like you've got a pretty good top end speed...what is the reduction ratio? Nice build!
HondaJohn
The bike has decent acceleration but it would be better with a CVT. I was actually looking at the same CVT that dougy used on his build but I wasn't sure whether it would work. Seeing his conversion, I think I will take the plunge and buy one. With the large sprocket (6.85:1) I get about 38-40 mph top speed, and it pulls fairly well up hills.
As a side note, I've just come back from the Loring Timing Association in Maine, USA. This bike now holds the speed record for its class (350 cc, alternate fuel). I was able to hit 56.5 mph with a lower gear ratio and a few dozen improvements. I will post images of it as soon as i get them ( was too busy fixing and racing to take photos, my friend who came needs to give me copies)
Hi,HondaJohn wrote:The bike has decent acceleration but it would be better....
I can see this is a long unused topic, but I guess it's better if I resurrect this than if I start a new one.
So, I'd like to figure out, how this single gear transmission works out.
Would this give me a more-or-less acceptable acceleration?
Would it give me a more or less acceptable top speed?
The idea:
I have a Jawa frame which has 350 2 smoker engine. the frame is simply too small for accommodating a diesel engine + a transmission, but this 1 gear-clutch version might just fit...
Using it as a commuter bike, the top speed I'd require is maybe 60-65km. So..... If I put in an engine which is able to give me more or less 5HP continuously, would that be able to give me acceleration?
How bad the fuel economy would be missing a top gear and revving the engine at 3000-3300 at cruise?
Yes,often it is better to resurrect than start a new one. One hint though when ressurecting is to quote a post of whom your trying to reach. Though not allways..... but sometimes folk have their membership settings arranged to get emailed when they are quoted in a thread..... Sooooo.. by quoting them..... odds are greater your resurection will actually reach the right people instead of floating in limbo land.hzoltaan wrote:Hi,HondaJohn wrote:The bike has decent acceleration but it would be better....
I can see this is a long unused topic, but I guess it's better if I resurrect this than if I start a new one....
Already threw a quote into your thread for you. Hope it helps ya get a responce.
Thanks, for the advice, I'll keep in mind.
HondaJohn
Sorry for the delayed response, I was busy prepping the machine for its second land speed race and fell off the earth for a bit there
If used on flat ground, the single speed works okay, but acceleration is a bit low, and you will throw up a cloud of smoke trying to get up to speed. A 10 hp motor and stronger clutch might help, as long as you keep it geared to a top speed around 40, but multiple gears is probably the way to go for keeping up with modern traffic. I spent most of the year developing a two-speed automatic to help with acceleration, and I detailed most of the build in this topic:
https://www.dieselbikeforum.com/view ... =31&t=1891
Good luck with your build!
