Jawa / VVM [dieselmaster]
vincentyeager
Re: Jawa / yanmar clone
Post by vincentyeager »
Even your daughter is helping, man you are a lucky bastard.
Good thing you keep them satisfied with the leg of lamb isnt it :D
vincentyeager
hi there, its been a while
the frame is at the powdercoater, in the meanwhile we tought lets do it even better and bought a paioli fork, brembo caliper, koni rears and akront wheels.
:D
XLerate
Post by XLerate »
Most excellent work, Vincent, thanks to you and Jeroen for sharing the exquisite details of the build! Looks like it should be great fun and keep on ticking [rattling?] for years to come.
I too am doing a bike gearbox for mine, modifying a GS550E engine. More like murdering than modifying. This will give me an auxiliary electric start, plus clutch & gearbox with 6 speeds up. Hoping it can cope with the turbo-diesel torque. I may have to add a flywheel too, similar to what you & Jeroen built.
Can't wait to hear & see more & see the finished product!
XLerate
vincentyeager
thank you :wink:
here's the frame before corund blasting/powdercoating;
and after, with the new suspension parts fitted;
:mrgreen:
XLerate
Post by XLerate »
And as the bike is being built so is Vincent's excitement! :)
Looks very good!!
vincentyeager
Here's the top nut, custom made by boutje as well as the rod underneath. In order to make the paioli fit to the Jawa frame.
vincentyeager
front brake nearing completion
only things left is making the disc fit.
isnt it becoming a beauty? :D
zarquon
Post by zarquon »
vincentyeager wrote:isnt it becoming a beauty? :D
Yes, it is!
Wow, this is a really top class build! I cant wait to see the finished product!
Love the progress, a lot of work is going into this and an inspiration applause for the effort ;), both the build and posting lots of info.
A ;)
XLerate
Post by XLerate »
Looks better than a factory build...
arnaud
Post by arnaud »
My compliments, hope to see it for real at the next Hamm rally!
vincentyeager
Thanks Folks!
Currently i'm spray painting all the bodywork. Expect some pics soon.
Color will be motip 55330.
vincentyeager
stickered before clear coat.
Nice. Is it possible to see this thing live?
vincentyeager
Hi Sphere,
please contact Jeroen (see VVM site) to make an appointment.
vincentyeager
time for a kick with a pic
arnaud
Post by arnaud »
i love it and wonder how the flywheel adaptation works out.
Don't hesitate to show up on the MF jawa topic!
vincentyeager
Ordered a nice little counter;
i ran into troubles because its hard to find gauges etc. of another bike
and the dutch regulations excplicitly say the speedo has to lit up.
tackled it all in on go with this nice koso DB-02R
has features like temperature, RPM etc.etc.
cheers!
I love this build! If I had more money and time and space :p this is how I would go about it! :)
vincentyeager
today was -as wel call them- 'headlamp ear' day.
Jeroen doing the welding;
pretty nice weld i must say.
after some more labour with four kinds of grinders & acid.
8)
Dougy
Post by Dougy »
Lovley bit of fabrication that ! :)
royaldragon
Post by royaldragon »
This bike is beautiful! :shock: I can't wait to see how it turns out. I am very curious to know how it goes after doing away with the forced air cooling.
dragonmotors.net
henneberg
Post by henneberg »
I like your carefull work in details. Finishing for ground-up projects with many new fittings always takes a lot of time and patience for most people :oops:
Keep going that way, exited to see the final result :)
boutje
Post by boutje »
vincentyeager
lets hope that 4000 km on a diesel are just as comfortable as on a laverda twin :lol:
in the meanwhile two wheels are newly spoked by the dutch expert ''haan wheels''.
and two new BT45's are waiting to be assembled.
Also, boutje and a good friend who's somewhat of a fellow electrician tackled the RPM pulsator issue.
The Koso normally uses input from an electrical injection system, 15-20 volt.
E.g. some conditioning had to be taken care of.
vincentyeager
hidiho!
the diesel is on its final set of legs. freshly spoked -front- wheel needed extra care, thanks for the wobble haan wheels (er zat een slag in) :o
New BT45 dual compound tires. Yes, this bike will need to go full throttle always and everywhere (also in the corners). :)
currently we are trying to assemble/machine the original ''brake anker''(?) onto the kawa 250 rearhub.
boutje fitted a ducati 916 hollow rear axle. :lol:
Its really starting to come together!
Looking good! :-)
vincentyeager
Here we see the rear brake ''anker'' (rod).
First time uploaded, straight from the VVMracing.com workshop
