bmw daihatsu charade
airfieldpaul
Post by airfieldpaul »
hi been going to build a diesel bike for years,bought a rolling bmw k100 chassis with gearbox,found a engine on ebay,got them both home,then moved into workshop so the wife said.any way got engine ontobox and in frame and running,would like to know if the k100 tank and seat will fit as i dont have these,dont want to buy them and find they dont fit can anyone help :D
bmw daihatsu
bmw daihatsu
realnutter
Re: bmw daihatsu charade
Post by realnutter »
looking good there!!!
having had a standard K100, my guess is that the seat will fit with no problems.... and probably the tank too... I'd like to see the other side before giving a more definate assessment......
But remember, K tanks are ally..so not as bash-able as steel ones!
airfieldpaul
thanks for that heres the other side
zarquon
Post by zarquon »
airfieldpaul
FANTASTIC THANKS FOR THAT IT LOOKS LIKE IT WILL FIT if there are any more pics out there for ideas would like to see them thanks
Crazymanneil
Post by Crazymanneil »
I quite like the K100 bikes. Seems like a good donor chassis with gearbox and shaft drive. One thing I wondered though is if it is possible to do something with the gearing since the original engine revs to 8000 rpm?
zarquon
Post by zarquon »
Of course you have to do something with the gearing. Especially on this one. The 1.4 TDI inside produces 75 hp at 4000 rpm and 195 Nm at 2200 rpm. It comes close to 200 km/h. That means it revs only a bit more than 2000 rpm while running 100 km/h. You have to change several gearwheels inside the gearbox.
K100 mit 1.4l Lupo TDI by bigzark, on Flickr
airfieldpaul
:D THANKS GOT FRONT END ON READY FOR TEST DRIVE AT THE WEEKEND,DOES ANYBODY KNOW WHERE TO GET DIFFERANT GEARS FROM?, IT LOOKS LIKE IT WILL BE CHEAPER BUYING ANOUTHER BIKE FOR TANK,SEAT AND OTHER BITS I NEED,WILL I NEED TO CHANGE THE CLUTCH PLATE FOR ONE WITH SPRINGS IN THANKS FOR HELP
Was once told groups like the one below are quite knowledgeable when it comes to joining German machines together :D
http://autos.groups.yahoo.com/group/vwmotorcycles/
