VW Powered Dnepr
Mouse
VW Powered Dnepr
Post by Mouse »
Its a new year and I'm starting another diesel bike project. Well that's a lie so start with, I bought the engine over a year ago and didn't do much as the V twin came up and at the time appeared to be a more viable project. I'm going to see if I can have it going by about Easter time then hopfully the problems will be ironed out in time for some summer use and maybe a trip into Europe if I can afford the time off work.
This is Me and Molly going to get the engine when she is still looking very much the puppy. The VW lump was a bargain at something like £25 from Ebay as a local sale and I couldn't leave it there.
The next problem was how to get it into a bike, I had a Dnepr frame left over from a dismantled sidecar project that was ready for for scrapping and after much thought and pondering decided to use that as a donor bike. The only part of the bike of any worth is the BMW rear wheel and drive shaft I had grafted into it some years ago. The main project idea is to slightly tilt the engine to the left side so it will miss the (raised) spine of the frame. Balance is maintained by bringing the bottom of the engine over to the right and conveniently in line with the drive shaft of the swing arm. Drive will be achieved by simply connecting the clutch to the drive shaft resulting in one gear ratio.
The faithful spread sheet tells me it will be doing about 12 mph at 500rpm and about 70 at 3000rpm. I'm guessing I'll have to slip the clutch to just above 12 mph or 500rpm where there should then be good torque from the engine and hopfully enough to drive in most road conditions. Although I doubt its capability of successfully getting up the steep side of the Applecross pass in Scotland!!
If you were wondering the VW lump actually weighs slightly less then the V Twin diesel in my other project.
Image]
Oh and I spent a lot of time double checking the direction of rotation so I'll be very surprised if that is wrong. :?
This is the engine mocked up in position, you can see the half built V Twin in there but ignore that for the moment. I'll only have to alter the top spine of the frame so helpfully as the frame is not significantly altered I'll get away with the same paperwork for it. :wink:
The first problem straight off was the clutch and flywheel. Two problems here. The first is that the clutch is operated by a push rod down the centre of the main shaft and this is simply not possible to utilise this in the set up I want. The second is that the starter motor was fitted to the original gearbox and that I am not using and I am not going to be using any part of the aluminium bell housing to hold it. I also want the bike to be narrow at this point so my legs and knees will fit in so want the starter on the engine side of the flywheel and the crown gear is fouled by the flywheel mass. So the only answer is to use a different flywheel.
After removing the flywheel I spot that the bolt pattern on the output flange are not even which gave me sinking feelings about finding a easy replacement, but it was off to the breakers to see what could be found.
Another £25 later and I have a flywheel that both fits the main shaft flange and has the crown gear on the correct side and is not operated with a push rod in the centre of the output shaft.
The first real job was to fit a starter motor. I obtained a starter from a 1.9 Diesel engine (I forget which just now) that spins in the correct way for this mounting orientation. Some mocking up was done to check it was actually going to fit, several starters were rejected in this process and I 'm glad I went to the friendly breakers for this where they are interested in odd mad projects.
The bracket was made from 4mm plate. A blank was and bolted to the engine on the gearbox mounting bolt holes so measurements and marks could be made.
After some careful measurement the plate was taken into the garden shed and trimmed down with an angle grinder so the starter bolted on with the gear teeth meshing up nicely.
You can see that the crown gear is mounted on lugs. This is because the original crown gear was to small in diameter and I couldn't get the starter to mesh with it as the body of the engine got in the way. I used the gear ring from the original flywheel which was larger diameter and surprisingly spaced correctly on a handful of M6 nuts!! Now that the starter is mounted alignment will be checked and the lugs / crown wheel will be welded permanently.
Then it was on to the heart of the project as without this being successful there was no way progress could be made.
This is the input shaft of the VW gearbox and in my hand is the output flange of the BMW bike gearbox. What I intend to make is some kind of Frankenstein monster from the two that will allow the VW clutch to connect to the BMW bike drive shaft.
This is it, the FrankenCoupling (Yet to be drilled) Made from the cut down shaft and a blank turned up on a friends lathe. The flange and shaft are not only two grades of steel but the shaft is hardened and finding information on how to weld them together was a nightmare. The blank was eventually welded onto the shaft using a high nickel content stainless steel grade wire, close to but not eutectic dissimilar matching grade specification. I heated both bits up in the oven for a hour and immediately after welding dropped them into a steel bucket of unused engine oil. This was for two reasons firstly the hope I'd restore some kind of hardness to the metal but mostly to stop the heat from rising up the shaft and softening the spline that will take the torque from the clutch.
The other bits that needed to be made are the support bearing housing that will hold the coupling steady.
This will hold a bearing that will allow a lever to depress the clutch spring.
A collection of odd sized bearings to make the whole thing work and tricky to track down as I had limited space and needed narrow variants of common sizes and the shaft was an odd but thankfully metric diameter.
The coupling and attachments mocked up in position. The next job is to make up supporting bracketery to hold this bit in place. The coupling support bearing bit will be bolted in place to allow easy disassembly in the expected frequent clutch plate exchange. :P
Spend to date is about £65 and I hope to keep the budget for the rest of the project just as low.
Re: VW Powered Dnepr
Ahh great stuff. Something to read with nice pics :D Call me a pessimist, but are you convinced that the engine will tick over as low as 500 rpm at idle?
Oh, btw, here's a nice picture of what bearing failure will do for you clutch. Roughly 300000 km clocked. Get it RIGHT the first time Mouse :D
zarquon
Post by zarquon »
Can I call this fearless? :)
Good luck for the project!
Mouse
Post by Mouse »
zarquon wrote:Can I call this fearless? :)
You can call it whatever you like, apart from Nice, Shiny, Show Winner etc......
Sphere wrote:...tick over as low as 500 rpm at idle?
I have no idea, I was imaging maybe it would have enough power at between 500 and 750 rpm to power it with out slipping the clutch. For comparison the 1200 bandit I have (with new chain and recently serviced) will ride down to about 20 mph in top gear and then pull away reasonably comfortably at that speed. The diesel should have comparative more torque at these rpm and hence my optimism
TedV
Post by TedV »
Mouse, do you have a fuel pump building guru in your area that can tweak the fuel pump to let the motor run at 500rpm? Most VW diesels I know idle at 900rpm. It should have enough torque to get a bike moving down that low. Im not sure I would like to be stuck in stop and go traffic with it tho. Course, I hate stop and go traffic in anything.
Mouse
Post by Mouse »
TedV wrote:...fuel pump building guru in your area that can tweak the fuel pump to let the motor run at 500rpm? Most VW diesels I know idle at 900rpm.
I'm going to get it running first. :wink:
900rpm approx 20mph, still very slow in the bike world, maybe I can live with that.
TedV wrote:I hate stop and go traffic in anything.
I'm intending this to be an 'out of town' bike. The big plan is to have the V Twin for short and intermediate trips and this one (If I ever finish it) for longer distances where most of the trip is on the open road and town traffic will be a fleeting inconvenience.
I also once spoke to a bloke who put a 1.6l ford x flow petrol engine into a single geared bike and he said it was 'manageable' in town. The conversation was probably 15 years ago so I forget details other than it worked.
smokyjoe
Post by smokyjoe »
Should idle OK at 500 RPM. My 1.6 Diesel VW car will idle REAL slow, but shakes like heck, at 500 RPM it is not bad but clutch chatters when engaging. I drove it in 4th gear when the shift linkage broke and stuck, I had to slip the clutch a lot taking off but made it home after stalling a lot. But, that was with a vehicle probably 1300 lbs. heavier than your bike will be!
Mouse
Post by Mouse »
Thanks for the encouragement its certainly the main debating point when I talk to friends about the project. It will spurr me on to finish the thing. I'm almost due another mega photo update......
Currently arguing with the DVLA over engine numbers and change of details......
Mouse
Post by Mouse »
Another update.
First is the air filters.
The original aluminium manifold.
From another angle.
Removing the surplus ally with an angle grinder.
The remaining tube parts shaped and filed a bit rounder and to resemble tubes.
As the manifold nearly but not quite clears the frame a spacer is needed. Ally is chosen as I had some the right thickness. The dimensions are faithfully copied out with a squirt of spray paint.
After some time on a band saw and the pillar drill followed my working a sweat up with my course file the spacer is finished.
There, a perfect fit!
Minimal clearance on both sides.
With the filters attached.
With the filters attached and looking cool.
Then on to the Alternator.
Do I use a car alternator or a Suxuki GSX alternator, size says it all really.
The donor pully and gear on the Suzuki alternator.
My crappy crap lathe just about capabler of turning out the pulley to git on the shoulder of the gear bit of the Suzuki alternator.
Hot! fresh from brazing.
Fitted and working.
The blown and useless Dnepr shocks. You can rebuild these but I have had two failed attempts in the past. Next to it is a Fiat 126 damper I had from when I threw away the 126. They are about the same length and diameter as the Dnepr ones.
After removing the spring and shrouding the Fiat damper is looking more and more like a compatible part.
There is no real way of converting the bottom of the damper to fit the bike so I cut the damper in half and the fiat damper cunningly slides inside it.
I had to buy a M12 fine die to cut a thread on the end of the damper so it would screw into the original top fitting. I also drilled and tapped the bottom of the original damper to secure the bottom of the Fiat damper.
Fitted and working. Very stiff and if it weren't for the extra weight this would be way to much for a normal bike.
CBR 600 radiator and fan. The radiator has a built in thermostat which made things easy for me.
The air filters were old so needed softening up before they would stretch enough to be fitted.
The exhaust and the start of the clutch arm and actuator.
It was at about this time my camera broke so there's no build blog worthy photos of the main construction.
Finished and on the road working.
Performance is exciting. Pulling away requires feathering oft he clutch up to about 15mph which is not as hard as it would suggest You can let the clutch fully engage at 10mph but it shakes a lot. After that it smooths out at 20mph and you can ride it normally from there on up to about 80 mph. It pulls away up hill with little extra feathering of the clutch. I won't take it to the calculated top speed of 105mph until I fit it with some more instruments like a tacho just in case I got it wrong or the Beval drive is not the suggested ratio.
The power delivery is simply awesome. Constant (nearly) torque from tick over right on up to max rpm results in constant acceleration and constant pull on the handle bars from 20mph right up to 80mph. Which is an experience like no other.
Initial fuel consumption with a fixed riding style for about two gallons (a tank) would suggest that travelling on the motorway with the city commuter cars at 70 - 80 mph with lots of wilful acceleration returns about 75mpg and sitting with the lorries at 55 - 60 mph returns about 91mpg.
:P
I'm now going to test it by riding to East Germany via Switzerland and mabey a few other places :)
YEAH! Kickass :)
Did you have to stretch the frame much? I also wonder about the gauze filters, and how they will shield your engine from particulates.
Ah well. Maestro, MUSIC!
http://www.youtube.com/watch?v=qRKNw477onU
Excellent build there Mouse :D
Mouse
Post by Mouse »
Sphere wrote:YEAH! Kickass :)
Thankyou :D
Sphere wrote: Did you have to stretch the frame much?
I had to raise the top tube by a couple of inches but did not streach the frame or make it longer.
I used every mm avaiable :wink:
It would seem the Dneprs are good candidates for car engines in Holland then, since stretching is baaaad (anything over 6 cm). I do wonder how the clutch/gearbox/finaldrive will hold up, stories you read they must be made of Silly Putty.
Good luck on your trip!
Crazymanneil
Post by Crazymanneil »
Cool as...
Always impressed by your ingenuity.
Mouse
Post by Mouse »
Covered over 2000 miles and am currently in Austria.
Only few things have vibrated off so far :D
Congrats :) Make sure you try the saucages with cheese, but don't tuck in before sufficiently cooled :o
zarquon
Post by zarquon »
I take my hat off to you!
balboa_71
Post by balboa_71 »
Mouse,
Nice job shoe-horning that VW power plant into the Dnepr! I watched your video when you were cruising over that high pass...seems your ride is both smooth and quiet. Can you tell us what vehical(s) the flywheel, clutch and starter you used are out of?
Thanks,
Mouse, did you manage to return in one piece? I was just curious, did you opt for the one-gear option because there is no room for a proper gearbox? How long is your engine block? Is this the standard Dnepr frame or its longer cousin?
Questions, questions :D
Mouse
Post by Mouse »
Sphere wrote:Mouse, did you manage to return in one piece?
Yea, been to tired and busy to get around to doing a writeup about it.
Fantastic trip!.
Sphere wrote: I was just curious, did you opt for the one-gear option because there is no room for a proper gearbox? How long is your engine block? Is this the standard Dnepr frame or its longer cousin?
As far as I'm aware its built around the Dnepr MT11. I have raised the top spine of the frame to accommodate the engine and altered the sump to clear the bottom right frame tube.
I went with one gear because without the gearbox I would only minimally alter the frame to take the engine. (ie minimally to pretend its a standard frame in the peperwork ;) )
Since building and riding I find the one gear although not optimal for pulling away wouldn't make me think about using a gearbox should I ever build a second bike with this size of engine.
It also drives well enough with one gear to be totally overloaded with luggage and drive from the UK to the Czech Republic without any real problems 8)
dotdies
Post by dotdies »
after congratulating you mouse for that great bike you' ve built (been thinking of a similar thing myself, after you gave that hint a year or two ago about the 1.6 engine on a motorbike), i would like to ask you how is the new clutch activated-operated. You said you didn't want to use the standard clutch as it is operated by a push rod down the centre of the main shaft and you also didn't want to use the bellhousing. Could you explain what type of clutch is the one you 're using and how it is operated.
My idea is to use the engine transversely and to hook a gear and chain to the clutch to get the motion to the back wheel... :|
dotdies
Post by dotdies »
all right i forgot to place a question mark at the end of my questioning sentence :?
How is the new clutch activated-operated? Anyone have a hint?
Does anyone think my idea is feasible (engine transversely...) or is it a proven pile of crappy thoughts?
Thanks!
