Google Laungage translation (Babble Fish?)
be for some time no longer maintained. More recent information can be found in some diesel-Wiki
AiResearch GTP550
Owner:
Emile van Essen
Builder:
Emile van Essen
known since:
07.03.2003
more photos
Emile van Essen from North Holland and was of the opinion that one of the original three-cylinder two-a 1976 Suzuki GT550 against a turbine could replace. So there was a 30 GTP AiResearch Turbine Built in 1967 found their way into the Suzuki frame. As the next turbine kerosene with diesel works include Emile in the elite circle of diesel bikers.
The turbine provides about 90 hp at 58,000 rpm. The idle speed is about 18,000 trips. Who runs the turbine needs a slightly different relationship to speed. For the initial force is geared for a Suzuki. The tank was a Ducati and borrowed to start the turbine was a 24-volt electrics needed. Nevertheless, the machine weighs just over 160 kg.
Technical Data Performance: 66 kW / 90 PS
Cylinders: T
Weight: 165 kg
Country: Netherlands
Quantity: 1
Status: rolls
Www.AiResearch.nl
Free Translation dot com
German Translation of the turbin powered bike- Best I could get. Tried dutch translation but it was a no go.
This database is maintained for long time no longer. More current information is found in part in the diesel Wiki
AiResearch GTP550
Owner:
Emile van meal
Builder:
Emile van meal
Well known since:
07.03.2003
1553 Proclamations
more pictures
Emile van meal comes from north Holland and was of the opinion that one could replace the original zweitaktenden three cylinder of a 1976 Suzuki GT550 also against a turbine. So an AiResearch GTP found 30 turbines model 1967 its way in the Suzuki frame. There the turbine next to kerosene also with diesel functioned also Emile belongs into the elitist circle of the Dieselbiker.
The turbine performs approximately 90 HP in 58000 revolutions. The idling number of revolutions is about ca. 18000 tours. Who turbine goes needs a something else relation to the number of revolutions. To the power transmission, the original Suzuki transmission becomes far related. The tank was borrowed a Ducati and to that, the turbines start was a 24 volt Elektrik necessary. Nevertheless the machine weighs only something over 160 kg.
Technical dataAchievement: 66 kW / 90 HP
Cylinder: T
Weight: 165 kg
Number of pieces: 1
Status: rolls
