Thinking about adding a turbo (for efficiency) to the D722.
Only issue is packaging.
Here are my downpipes:
The only place I can see it going is where the X is:
click images for larger versions.
The specified location poses a few issues.
1. Ground clearance, its the lowest point of the bike.
2. Space for air piping etc is limited.
3. Being below the sump will mean a scavenge pump is needed which seems like its too complicated.
I would be going with an IHI RB31 Clone, which should build lots of boost very low down on this engine. It is also very compact.
Thoughts?
