Reviving project after move
Just starting to get the project back on track.
Was putting a D830 in place of the D850, after the D850 had low compression on one cylinder.
it has a small set of differences, but the crank case size is the same.
Its bolted up and is driving the rear wheel but needs:
[*]Engine mounts on crank pulley side
[*]Alternator mount
[*]RPM counter sorting out
[*]There are no electrics for some reason?
[*] fuel tank needs cleaning out
lots of other bits!
Started straight up in -1deg weather 5 seconds of glow :
https://www.youtube.com/watch?v=rvGvcb8bqW0
New engine has done about 12 hours.
Re: Reviving project after move
Glad to hear your back on project. Confused though. Video says engine is a D850.... thought you were replacing the 850 with 830?
coachgeo wrote:Glad to hear your back on project. Confused though. Video says engine is a D850.... thought you were replacing the 850 with 830?
I am , its a typo :)
