Hello
I'm looking into the possibility of building a Diesel Monkey Bike. I'm from the Monkey Bike scene here in the UK & have no shortage of spare frames etc. I'm interested in the possibility of such a project. Tentative research has so far found the smallest engine to be approx 44kg with an output of approx 5hp, whether this is sufficient for useful road use I couldn't say?
What I would like to know is what the best engine would be for my needs & if I would need to use a transfer box? I'd like to avoid Chinese if possible, but if not it's not really a problem. Thanks in advance.
Diesel Monkey
Re: Diesel Monkey
Still a big motor Toby, but worth a try all the same, most can be tilted by 20 degrees or so.
A simple go-kart clutch would probably be the only transmission you could fit anyway as there would be no space for a countershaft or gearbox.
best of luck
best of luck
Re: Diesel Monkey
Appreciated.
I've seen some smaller engines in pictures, diesel bantam being one. Any advise what they might have been?
Re: Diesel Monkey
Thanks for your help, I really appreciate it. Can you recommend some reading material to learn a little more about what I'm looking at. Others have said I can get away with a centrifugal clutch on the end of the output shaft rather than using a torque converter. This sounds appealing as I suspect it would be a smaller package but I'm guessing the torque converter gives a higher speed? I really whatever I end up with I'd like to achieve 50mph. Could you recommend a combination of engine & torque converter, if indeed I need one. Thanks again.
Re: Diesel Monkey
Most conversions use a 10hp engine and this gives app 55mph using a manual gearbox or CVT.
If you are considering a mini bike you will be struggling for space.
Have a look at this post.
https://www.dieselbikeforum.com/view ... ilit=dougy
