IronDieselButt
- TimppaX
IronDieselButt
It needs dedicated finn and diesel powered sidecar Dnepr to make BB1500 drive
Snip from Iron Butt Association of Finland´s web site:
Isosalo Juha 2558 km 1590 ml 6.7.2007 Dnepr 900 Sidecar Diesel
Kubota diesel + modified transmission gave enough speed. Yet no idea of fuel consumption.
that should do it
Hopefully we will see some pictures and learn more about the engine and gearing. With the Kubota engine installation the Dnepr will probably weigh around 800 lbs.
Here's what I suspect: A 900cc Kubota puts out about 25hp maximum. At 3600 RPM the engine would be *theoretically* capable of about 60 mph with the standard 4.62 final drive and about 70 mph with 3.89 gearing, using a custom gearbox primary shaft for a 1:1 gearbox ratio. The custom gearbox stuff is shown on the motopan website:
http://www.motopan.com.ua/foru/korobka_e.htm
Years ago I installed a complete 750cc BMW drivetrain with a 3.89 final drive in a Dnepr. The stock engine put out 30 hp at 50 mph and it was no speed demon. Later I installed a factory Sport camshaft which made a huge difference
A sidecar outfit requires a lot more power than a solo motorcycle once you go over 45 - 50 mph.
I know what you mean about imperial vs metric. Here in Canada we switched to metric in 1975 and I've been confused ever since
95 km/h @ 3500 rpm is 59 mph which is what you would get with the 10/35 final drive and the stock 1.3:1 gearbox. The 10/35 final drive is interesting - I didn't know there was such a thing. This would probably be of interest to others with diesel powered Dneprs.
Avery
Avery
- TimppaX
I can easily handle distances either in feets or meters as inches and centimetres but never do remember miles vs kilometres.
Also why report fuel consumption in mpg instead litres/100km?
Anyhow:
Parts are partly custom made in Finland or original custom parts from russia/ukraine.
Gearbox wasn´t either stock. 3rd & 4th drives were modified a lot.
Wheels are standard 19"
Anyhow:
that should do it
I can never do the litres 100 km thing, why not km per litre ???TimppaX wrote:
certainly gallons to teh 100 miles is very odd.
I will go metric when teh french do.. and that will be never.
they will have to changetheir language to go metric, and stop selling wine and eggs in crates of a dozen ( without using the buy ten and get two free trick)
I dont know what you find so difficult about the imperial system.
Wheels are measured in inches far easier than them millimeters things.
I will try to explain,
4gills=1pint, 2pints=1quart,4quarts or 8pints=1gallon. 2gallons=1peck,
4pecks=1bushel,8bushels=1quarter.
12lines=1inch.12inches=1foot.3feet=1yard.5 1/2 yards=1pole or perch.
22yards=1chain.10chains or 40poles or220yards=1furlong.8furlongs or 1760yards =1mile. 3miles or 5280yards=1league.
What can be easier than that.
- TimppaX
I´m into measuring blackpowder in grains, instead grams due accuracy + most of reloading manuals handle weight in grains. I have electronic precision scale and metric vs imperial is just one buttobpress away.
Oddity is to base measuring other than 10-base scale. Most of us have 10 digits. Imperial lenght measures are mostly based on body measures of a widely respected person. Ie 1" is measured from thumb foot was lenght of emperor´s own foot etc etc.
that should do it
There is some evidence to suggest that North Indian and europeans originally counted to base 12. Virtually all those languages have single words for the first 12 numbers. Certainly in India , most who count regularly will use base 12. If you look at your left hand palm towards you, you can count the 12 segments of your four fingers, Once you get to 12 you can carry over to your right hand. thus counting up to a maximum of 156 on both hands.TimppaX wrote:I´m into measuring blackpowder in grains, instead grams due accuracy + most of reloading manuals handle weight in grains. I have electronic precision scale and metric vs imperial is just one buttobpress away.
- TimppaX
Also somewhere in the pacific are tribes known to have numbers from 1 to 3 and everythin else is considered just to be more. Somewhere in Africa too?
But back to topic:
Jus had loooong conversation over phone with a guy whose bike that was:
Gearbox is standard(!) Dnepr gearbox with reverse. Job was done with customized final drive to the ratio calculated to achieve 95km/h.
Consumption was, according preliminary data, around 22,22km/litre, ie 4,5l/100km. This data is only preliminary.
During the drive itself there was heavy rain, nearly all the time.
Driver stated that without sidecar this kind of drive is unpossible due fatique and weather conditions.
Technical problems: None
Wear and maintenance: One rear wheel, no added oil.
I`ll have to wait for final data & photos.
But back to topic:
that should do it
For those of us who are metrically challenged, 4,966 litres / 100 km works out to:
1.092 imperial gallons/62.137 miles = 56.9 miles per imperial gallon
1.311 us gallons/62.137 miles = 47.3 miles per US gallon
This is better than you can normally achieve with an equivalent weight gasoline powered sidecar outfit when riding at 95 km/h (59 mph). I averaged 42 imp. mpg (6.7litres/100km) with my BMW 750cc boxer powered Dnepr and a friend averaged 45 imp. mpg (6.3litres/100km) with a dual plugged BMW 750cc boxer sidecar outfit on a 600 mile ride at an average of 90 km/h (56 mph) .
Avery
Avery
I found a supplier of the 10/35 final drive gears, the same ratio as used in the Iron Butt Dnepr. They are available from F2 Motorcycles Ltd. for £90.00. The gearset is shown on their web page:
http://www.f2motorcycles.ltd.uk/dneprupgrades.html
It would be interesting to know who the manufacturer is to get an idea of the quality.
As stated by TimPax, this setup is good for about 95 km/h (about 60 mph). Add a modified 4th gear set (various ratios available) from Motopan and you could get a theoretical 128 km/h (78 mph) @ 3600 rpm from your Dnepr.
Avery
Avery
