I’m planning to install a 10HP clone in a CB250. I usually put more emphasis on reliability than performance. That being said, I’d rather have a remote oil filter than the screen type use on these diesels (maybe both?).
I know the turbo crowd feeds the turbo from a pick up point at the oil pump and return the oil to the oil pan, but I haven’t seen a good picture/detail of the pick-up and return points. Could somebody post some pictures of these areas (what you have done) and explain if a restrictor would be needed (of what size, etc.).
From the question, you already know that I don’t much about these engines… hope to learn a fair amount from here…
Thanks,
JJ
Oil pick-up, restrictor and return
Smoky&thebike
- I don't post much...
Re: Oil pick-up, restrictor and return
I suspect you would need a restrictor. The easiest place to take the pickup from would be the oil pressure port.
I do wonder what my screen looks like. My engine has 3500 miles on it, and I havent taken the screen out yet (its sandwitched between my gearbox and engine).
I monitor my oil pressure closely.
sorta hidden post down here at the bottom. Easy Newby mistake. If you PM a moderator to move this post to the appropriate section you'll get a ton mor responces.
The small motors usually have an optional kit for a remote oil filter; reason being that some of the installations would make it impossible to change the std internal filter.
