Okay, I've been playing with the old Goldwing engine/tranny for a few weeks now! While I could separate the transmission and clutch assembly from the cylinders, the layout would stink for use with a diesel engine.
So, the new step is to use a small (2 or 3 cylinder) engine with a stubshaft. Install a Comet torque-a-vertor on the shaft and run that to an independent jackshaft. On the other end of the jackshaft, I'll run a chain back to the bikes original driveshaft that comes off of the back of the engine. Of course there will be all kinds of shaft supports needed.
The torque-a-vertor will obviously control the clutching and "gear changes". The jackshaft will allow me to somewhat center the engine in the frame and the final set of gears/chain will allow me to adjust final drive gearing.
Anyone understand what I'm thinking? I'm sure I've done an awful job of describing what I'm envisioning!
GL1000 project............
Bugger! It would have been a much easier job to use as much of the original drive train as possible.
I thought about the plan you had, sorta getting my head around what you are thinking. Would a BMW box or similar be easier to adapt then using a lot of shafts etc. Just thinking the drive train is as strong as its weakest link.
Still it would be interesting to see what you have in mind with a diagram/mud map!
I'll have a look-see at a link I know http://www.bikebandit.com/ and see if they have a few exploded views of various in-line engine transmission motorcycles.
I'm waiting for a mate to drop the covers off his VT 1100 to see how its all mated up with the engine and transmission. I know the CX 500 had the engine and transmission in the same casing - Damn.
The VT 1100's are still pulling big bucks, so I don't think I'll be doing any new conversions for a while
Andrew
Andrew
Here's a picture of my Daihatsu D950 mated to a BMW gearbox using an adapter I made up myself. This picture and several others of the project currently being displayed on the dieselkrad website at:
http://dieselkrad.info/dieselmotorraede ... avery.html
Avery
Avery
Thanks for posting the diagram up Byrdman, it's what I thought you were getting at. Would be good to have part of the transmission system enclosed somehow if you were going to go that way?
Avery! Looks like a very neat setup - well done. This is something I think I'll look into if I start a multi cylinder conversion.
Firstly - I'd have to get through the red tape here! That's going to be the most time consuming and expensive part, something I probably won't be able to manage for some time. It's totally ridiculous
Andrew
Andrew
- LocomotiveBreath
Honda 1000?
What you all are doing is the same as I'm doing but with a Honda GL1800 final drive and a centrifugal clutch instead of the CVT. Also I see a fellow member (cdog) has done the same seen in our forum @ http://tinyurl.com/yscq7w
I have parts machined up for those that might be interested in doing the GL1800 final drive, they are cheap (see: http://tinyurl.com/yrbrcs ), bullet proof, and come with 316mm ventilated floating disc with a split port caliper for actuation either from front, rear, or both braking.
If any are interested, feel free to contact me. http://img452.imageshack.us/img452/7277/dscf0007ax3.jpg
Also note, the GL1800 final drive have a standard 2.75:1 ratio also I have heard 2.86:1 also, I have five (5) complete setups and I think they are worth looking at. Also they are one sided, and have a 5 on 100mm bolt pattern.
