Which 10hp diesels with electric starts will fit an Enfield
Sibbo
Post by Sibbo »
Which 10hp diesels with electric starts will fit an Enfield without cutting the frame ? I'm very interested in an aerofairing but it may restrict kickstarting room .I know how to kickstart an Enfield , I've had one before ...if not now but there may not be room on what I build .
It appears the Chinese clones will not fit with the starter installed ,it has to be removed .Any other possibilities ?
Sibbo
Re: Which 10hp diesels with electric starts will fit an Enfield
Post by Sibbo »
I've found an answer to this .In my state if the bike is pre 1970 I can modify without restriction .... and I've found a 1965 Indian import that I can chop and fit a clone with starter fitted .
nanno
Post by nanno »
The Hatz 1B40 will fit with the electric starter still installed.
(Check out Sommer Diesel Enfield)
The Hatz is ridicolously expensive though.
Cheers,
Greg
