You can have a look at:
http://www.youtube.com/watch?v=jmt20ryUJ4M
The answer to that is neither! The governor itself compresses the sprung plunger fully when full power is requested by the throttle when revs are lower than full rated speed. Or at a steady speed with the twist grip at, say, halfway, when a load is imposed upon the engine that reduces revs below that set by the throttle. The nature of the governor is to maintain revs at the level set by the tension upon the governor lever from the spring attached to the upper lever connected to the twist grip. Therefore the governor may be forced to inject maximum fuelling ( fully compressing the plunger ) at idle revs if a resistance is placed upon the engine, - or it may not need to depress the plunger at all even at 3600 rpm if the loading is very light. ( because a diesel is unthrottled in air intake, there is more than enough fuel going in at idle to spin it to destruction without governor control ) All you have to do, is to ensure that even under full load conditions, the fuelling is sufficiently reigned in so as not to produce black smoke, (which can quickly overheat & burn the piston) - so that maximum power is maintained while producing little visible smoke. If you begin by adjusting the screw so that it very lightly touches the governor arm with the engine off, then go for a ride. You will probably find that the engine is rather gutless. If so, wind out the screw one quarter turn, making sure it doesn't move as you tighten the locknut. Go for another ride. If still flat, adjust outwards again by one quarter turn, & repeat process until satisfied that full power is being produced without noticable smoke. If you know your gearing, & the road speed expected at 3600, it will make it easier to ascertain performance on the level. Maximum engine revs are set by the vertical screw next to the throttle cable, & is completely independent of the horizontal fuelling screw. Again, if you know the calculated speeds expected in the individual gears at 3600, you can better ascertain performance & keep revs to within manufacturers tolerances. The engine shouldn't exceed 3800 when not under load. Good luck!skoleskibe wrote:Do you guys set the "mystery" (spring loaden) adjuster so it's active, meaning that the spring in the adjuster is compressed when running full power, or is it adjusted to just tuch at full power.
