yanmar 2t75
caddyman
yanmar 2t75
Post by caddyman »
Hi All, looking for an engine for my first diesel build, would this yanmar 2t75 (16hp@ 2900rpm) be suitable?? , got a ural donor bike, or can look at building frame etc....
regards chris :D
Re: yanmar 2t75
HP looks good but the Revs wouldn't get you much speed at all. You maybe able to tweek the guvnor up to 3800? Then you might just be able to keep up with the traffic and be safer.
caddyman
Re: yanmar 2t75
Post by caddyman »
Would something like a Kubota D600 be a better bet, or stick to single cylinder?
Re: yanmar 2t75
I think that would be more suitable yes. The Ural is quite large and would be better with a multi cylinder engine. Checkout the other builds using Ural frames for tips. Much better pulling power with all those pistons working for you :D
caddyman
Re: yanmar 2t75
Post by caddyman »
Thanks for the advice Stuart, i think i will get the ural registered as is first then do the transplant :D ,im watching a similar build at the moment on the forum and will hopefully be collecting all the parts req'd to get started :D :D
