Throttle mechanism engien side
I'm looking for a clean solution (preferably pictures) of the engine side of the throttle assembly.
It needs to:
- have adjustable min/max settings, since my engine no longer maxes out at 3600rpm
- have some sort of spring mechanism to pull the lever back to neutral when releasing the throttle
- ideally it would have the min setting supported by a heavy spring, so you can pull it past the min setting so the engine shuts down
Now... the problem is not that I cannot make it. But, I don't know which kind of nice standard components there are, so I can just buy something in a shop when it breaks. Photographs of your own implementation are also highly appreciated. Supposedly it is one of the final steps until I can patiently await the moment where road salt no longer dominates Holland :roll:
