Since it is easier to use a different transmission than try to get this pulley to fit on my engine, I'm selling my BRAND NEW Comet 94C CVT clutch p/n 206094A. It is good for up to 30hp and has a 30mm tapered bore. It comes with the pink spring (low rpm engage for a diesel) a puller bolt, and a long mounting bolt. Also for sale is a Comet 90D secondary pulley. It mounts to a 1" keyed shaft. It has been mounted to a shaft but has never had a belt on it. The combination will give you a 3.4 to 1 low ratio, all the way up to a 0.78 overdrive. The spring for the 94C alone is worth $25 but I'll sell the 94C stuff together for $275 which is a lot less than you pay on eBay. I'd like $150 for the 90D, but I'll give you a deal if you buy both. I'm also up for trades if you have something I might need (or find interesting).
Cheers,
Phil
For Sale: Comet 94C CVT and 90D secondary
Re: For Sale: Comet 94C CVT and 90D secondary
Since you're from Canada it might be worthwhile to specify CAD/USD. Not that it matters much anymore these days. In CAD it's an even bigger bargain. A shame Nanko will disown me if I buy it
DogPatch06
- I don't post much...
Have you still got that 90D driven for sale? They're practically impossible to find.
Hi have you still got your comet 94c and 90d for sale ?
