regulator/rectifier for 12V/200W
After prematurely ending the life of an innocent light bulb (may the Diesel God have mercy) it is obvious that I need to reinstall my regulator. Unfortunately it has been "misplaced". I've tried to locate the Enfield regulator and alternator specs in order to determine if this is a viable candidate, but I can't really find useful information.
I guess it needs to be something that can dissipate in excess of 200-250W (safety margin?) because Murphy dictates that the headlight will die on me at 3600rpm leaving almost no other major consumer. Any idea about the Enfield one or replacements?
Nanko
Re: regulator/rectifier for 12V/200W
Just made a quick test with some junkbox components
With a resistor , a zenerdiode and a MOSFET I created
a nice 10 Amp voltage limiter .
Voltage absolutely stable between 0,25 and 10 A.
On lower currents the voltage drops 2 V ,have to correct
that , because the regulator is connected parallel at the
battery
So making a rectifier/ voltage limiter seems to be easy.
Next step is upgrade the limiter to 20 A 250 Watt
When succesfull and if there is interest I can post
pictures and a diagram
battery
johnfireball
Hi,
The enfield regulator gives problems at only 100 watt output, I think at 200w you need a better one.
John.
John.
Mouse
I'd like to see the diagram when you're ready. A friends diesel Enfield had a broken regulator and I'd like to sort it for him.Nanko wrote:Just made a quick test with some junkbox components
I guess we'll be testing the prototype this weekend. If I get the wiring sorted
If they ever open a branch in Holland I will let you know
Nanko
Not for permanent magnet alternators , fitted in most stationary engines.
They need a parallel regulator , when voltage reaches 14 V it shorts
the AC output.
Thyristors are used in spheres prototype , big advantage is dissipation
is low.
More info next week
I can tell you that the stator on a DRZ400 will put out a max of 200w...
So the reg/reg will be able to take it, so perhaps it would be a good candidate...
If you do get one, connect the red and black (with white stripe) directly to the battery terminals...
Will then give the battery a good amount of power
snoopy
Wasteful of energy though. At 10hp it will make a difference.
Try a cheap switch mode power supply on ebay. Here's one that will handle the headlight wattage, http://www.ebay.co.uk/itm/4-35V-DC-Conv ... 3366666c26
