Diesel Tiger II
Re: Diesel Tiger II
Up to 92mpg now.
Re: Diesel Tiger II
Dave,Diesel Dave wrote:Up to 92mpg now.
What is vibrations like? Have you been on a non diesel tiger to compare? You got seat time lately on any other non diesel bikes to compare with?
On reason Im asking is wondering if might should consider loosing the engine as a structural member and add that back by building in an engine basket then rubber mount the engine in some manner.
Re: Diesel Tiger II
What about noise? Need earplugs? Would neighbors have a problem compared to sound of a petrol bike of this size?
Re: Diesel Tiger II
Yup it's a noisy bas*d, it's mostly intake noise as there's just a K&N conical in the way.
The handling is pretty good despite warnings from all and sundry about Tiger headshakes, I did over 100 miles on Sunday with a full topbox and the missus on the back.
It's nothing like a petrol motor, the rev range is very short and the rev's will sit wherever you want them too depending on how far you open the twistgrip. It sounds odd for folks unfamiliar with how a regulator works. Normally the twistgrip or throttle controlls the amount of power, on a diesel it's a request for revolutions - a bit like a ships telegraph to the engine room. You don't notice this on a small single because you always want more revs/power.
Re: Diesel Tiger II
looking closer.... is there no longer a flywheel or was it shrunk a bunch orrrr?
Re: Diesel Tiger II
The flywheel is still in there, it's much smaller than the ones fitted to single cylinder bikes, it could do with a few pounds being shaved off it.
Re: Diesel Tiger II
Thanx Dave.
I'm wondering if there is several fly wheel options and Heicko chose the smallest diameter available to use. It sure looks tiny in circumference compared the one on the Kubota.
Re: Diesel Tiger II
Please explain and show pics or drawings of where your Alternator is?
Re: Diesel Tiger II
I don't have any pics but it's inside that flywheel.
There are 2 types available 20A and 30A, interestingly the 20a is 3 phase and the 30A is single phase.
Re: Diesel Tiger II
ok... so these internal type alternator is a Lombardini product?Diesel Dave wrote:I don't have any pics but it's inside that flywheel.
Re: Diesel Tiger II
Yes they are optional fitments from the factory.
Also optional are electric engine stop and automotive regulator controls, (I don't have these as I wanted the mechanical engine stop and with the std regulator yiu can use a twistgrip hold as cruise control.
