Removing the engine and dissassembling the engine has revealed some interesting things...
1 the crank shaft is not welded on the crank pin but the weights are welded in place.
2 there is a oil by-pass valve , but also a drilled passage that sprays across the case, not sure what the deal is with that.
3 after spending som time with a dial indicator and degree wheel, the v is not 90 degrees, its 80 degrees, one more reason the odd exhaust note.
Having the degree wheel in place makes it so much easier to dial in the goofy injection pump, a few modifications and possibly a few parts from china and i will be turbo charged, everything seems to be running well, no damaged parts so far.
After emailing Frank at mgs in china he has told me they have changed about 80% of the parts on the new 22 hp engines, i guess they are making progress with this unit.
oh the fun and games
