Hatz 1B40 decompression system
Can anyone elobrate on the Hatz decompression system? The pullstarter shows a guy pulling the rope until compression, then rolling the rope back and pulling for start. For a 1:22 compression ratio it seems unnaturally easy to turn the flywheel by hand. However, there is no hissing noise from the valves or anything.
Re: Hatz 1B40 decompression system
If it's anything like the Yanmar/Yanclones, it holds the exhaust valve down a fair way over the compression stroke, so much so it will not hiss but not far enough to hit the valve on the piston crown.
A
A
Apparently it has some kind of autodecompression, I don't know if the Yanmars have this.
No, you have to physically pull the lever down on the Yanmar/Yanclone.
A;)
A;)
