Yes the bearing is rough to turn by hand, I'm interested to see the balls, the cage nearly completely hides them. Surprisingly there is no free play, it is easy to get the bearing to nip up, so one or more balls might have flat spots, the only way I heard this bearing was with a little gas fumigation. The new engine is really quiet, no rumbles at all.
I agree sphere with your comment, a new main bearing and off the engine will go again. Other parts I have thoroughly inspected and found cams etc are all good, the engine never used oil, started easy and really ran fine, that is why I thought it a good idea to change the bearing before any failure. I'm going to keep an eye on rpm with this new engine.
The 10hp yanclones are also getting hard to get hold of here, so keeping the engines in good condition is a really sensible idea.
Chris, the engines are easy to pull down, I've left the head on, only taking the rocker cover off momentarily to loosen off the rocker adjusters so I could pull the cam assembly out. The fuel pump was also loosened to do the same.
They are a really easy engine to work on, get hold of the yanmar L100 manual in pdf format, the link is on here somewhere, if you have good mechanical skills it's an absolute breeze, the only thing you might need help with is the pressing off and pressing on of the main roller bearing.
my engine knocks so loud, it overwhelms to exhaust note coming out of my bikes straight pipe
Yes I know, they really knock hey
, that is normal for yanclones and many other single diesels with little noise shielding. The sudden burning really gives it a hard knock, the fact that there is no variable timing also makes the engine unnecessarily louder then they could be.
