An interesting observation tonight.......... or maybe it isn't interesting at all. I was firing up the old Hatz E79 prior to hacking it into the Suzuki frame and I had to remove the muffler to check out the cleanliness of the PCV valve. Being the lazy lug that I occasionally am, I left the muffler off to test run it to check out the valve lash and PCV operation. For some unknown reason I decided to get a flashlight to look into the exhaust port with it running and lo and behold there was a LOT of oil on the exhaust valve stem (could see it slobbering around as the valve did it's thing) with some drops occasionally blowing out the port on to my flashlight lens. With all the no-load test running I've done in the process of fiddlin' with this thing, this engine doesn't seem to blow much smoke (except when opening the throttle quickly) and there wasn't any blue haze as I got with my old VW Diesel when it had bad rings. (Well, at least my exhaust valve stem is getting lubricated). In all the hours that I've run this engine it hasn't seemed to use any oil. Oh well, with the high cost of Hatz parts this engine is staying as-is except for maybe valve seals, if it decides to head west I'll part it out on eBay and throw in a Yanclone, unless I can find a source of "cheap" surplus Hatz parts.
Surprisingly, exhaust noise seemed the same with or WITHOUT a muffler!
The MOST interesting observation was concerning carbon dioxide emissions. The mosquito population in this part of the country has been thriving with all the rain we've had this summer to a record level. Even though the temperatures have been near record low, the mosquitoes have been NASTY! As I was working outside the little buggers were there, but few. Then soon after I popped a brew, they started coming around (sensing the carbon dioxide emitted by the bubbly). All heck broke loose when the ol' Hatz started chugging to life. I was being eaten alive by the blood-suckers to the point that I hurriedly stuck the muffler back on, threw a tarp over the mess and escaped reluctantly to the safety of the house to finish my beer.
Mosquitoes, being attracted to carbon dioxide, may be erringly maligned as being a useless disease-carrying pest. Maybe Al Gore should tap into this natural champion of the environment and publicize the great deed these little creatures do to force us to lower our carbon emissions. You see, the more carbon dioxide you emit, the more blood gets sucked out of you and the more uncomfortable you are made to feel. Forget carbon credits and all that other nonsense. Just let the mosquitoes thrive and do their thing.
Or on second thought, where did I put the bug spray?
