dnepr and single diesel engine
Hi, on this site; http://www.dieselbike.net/Hamm08/Hamm08.htm
is a pic of an dnepr with, i believe a single cylinder china diesel.
since the length of the engine(especially the flywheel) and the outlining with the gearbox and final drive would be a problem, many people who installes 2 cylinders were forced to adjust the frame.
But this one, despite the vague pic, seems original??
Maybe is it something I can do if it is unaltered!
however, a small twin (would a 483 kubota fit) would be better since the final drive takes far more power then a chain..
The frame on the bike has definitely been modified. I edited a part of the picture, adding lines to show:
(A) the modified tubes under the seat (now curved upward. The backbone appears to be almost horizontal.
(B) the engine has been installed on an angle which allows the base to rest on the downtubes.
FYI
FYI
It would also be cool to see someone convert the boxer twin to a diesel like was done to the Harley screaming eagle engine.
As you mentioned Arnaud, a heap of space could be gained by shortening the flywheel section if a suitable clutch system fabricated.
I once looked at the Chang Jiang motorcycle as a diesel project which has a similar box engine etc. Pistons and head design are big engineering feat, bottom ends in some engines are very strong, some not so strong. A lot of factors to consider I guess.
i think the most simple thing to do, is buy the one with the shortest axle(you can choose from several types with a china diesel) and mount the dnepr flywheel and clutch on it, or maybe a smaller one would fit, if the clutch operates the same, for instance the one from a honda CX500?
the most difficult to make will be the mount between the gearbox and engine which have to line out exactly
johnfireball
Hi,
the Dnepr frame crossbar is very low where it meets the frame at the saddle and will I believe require cutting and welding for allmost any upright diesel engine.However it's easily done and I think you would not have to lengthen the frame if one of the smaller 2 cylinder engines was used with a bellhousing made to minimum width.
John.
John.
roverthetop
hello forum,
on the dieselbike.info page is a bike shown that
follows a easy concept, please take a klick
http://www.dieselkrad.info/dieselmotorr ... +1B40.html
this bike based a a dnepr with singel cylinder hatz engine, it looks easy to build.
i remenber a post of the owner taht he used a some real axel sprocket (tooth wheels) to have a longer gear, he import them direkty from russia.
i didn´t see the bike on the meeting this year in hamm.
so i hope it works well.
it´s a simple thing to build drivewind cooled engine, then the flywheel (perhaps designed for that) moved to the gearbox side. if the adjustment is well, i think it will work properly. it looks like a good concept.
regards helmut
ps: first note without a detailed introduce...
will follow soon this some details of my diesel bike project.
pss: sorry for simple englisch
regards helmut
DNEPR CONVERSION
Both Dnepr and Chang frames have insufficient space for most upright engines, and Ural has even less, so in most cases, the frame needs some alteration. V twins are more suitable, of course, but we are limited to Chinese engines.
I sized up a three cylinder D662 Kubota to my frame, originally. It needed only an extra six inches or so, not allowing for the radiator, but to save weight and plumbing , I opted for a Petter twin for my contribution to the DIY section of the Diesel Bike Scenario. Frame modification is drastic (see picture), but its "industrial" looks should attract some attention.
As for converting the original engine to diesel, my opinion would be that, even given a stronger crank (last estimate obtained for this was £500), it is unlikely that the Dnepr cylinders would hold up. Chang cylinders look meatier, but, again, the strength is unknown. One thing in favour of the Dnepr crank is the one piece plain bearing design, so if someone would like to find a way to beef up the crankcases, bearings and cylinders it could be in with a chance. I have a dismantled engine for sale........anyone???
Stormcoat.[/img]
Stormcoat.[/img]
Nanko
Is it the compression or the combustion stroke giving the biggest stress on the bearings?arnaud wrote:since the compression ratio in a diesel is about 3 times as high, i don't think an russian ural or dnepr crankshaft is suitable for diesel rebuilding..
i.m.o. its the combustion , check max torque from both engines if there is no hughe difference and dneprs dont have crankshaft bearing issues , its worth a try
Re: dnepr and single diesel engine
Most success with Dneper that can hit success full highway speeds (safe highway speeds) have been 3cyl engines with minimum 18hp. Smaller engine and you can cruise the backroads at a smell the roses 45mph or so.numuzmar wrote:i am also interested in this bike.... this is 4 or 9 HP engine ? its enough for heavy bike like dnepr ? (dnepr without sidecar weights 220 kg.)
what speed can achieve this bike?
oh many questions =)) maybe some one knows how to contact creator of this bike?
Search this site for the various types of bike you are interested in and you will find discussions that will lead you to the answer you seek.
