i fixed for an coustumer in his enfield the 6 speed ultima gearbox in an enfield frame with the 505ccm lombardini engine. i am strained how it runs with 6 gears.
but first i had to make the alu primärcover and brake.
heiko
Is that right side drive you are thinking of? Where the final chain/belt drive comes out the other side of the box? I've never seen one of these admitedly - there is not much in the way of a harley/parts scene over here.Sphere wrote:Don't those ultima boxes come in both rhs and lhs flavors? Just one is 100 bucks more expensive? That's what I gathered from browsing ebay.
DOH! I see you've cut the starter plate away on the tiger too - I wondered why it looked such a neat job!Heiko wrote:hi
yes i cut all staff what was for the starter.
its in way .
yes all enfields you can build with that gearbox without changing frame but its much work.
but all here must like work because off driving a diesel bike. it always somthing to do.
ciao heiko
yes its from vdo.oilburner wrote:Are you using a VDO drehzahlmesser electrische? How do you generate the signal?
Thanks
many thanks for your compliments.oilburner wrote:Heiko, I forgot to compliment you on your excellent workmanship and well designed diesel conversions. I am particularly impressed with the clean factory-like appearance and high quality custom parts. Thanks for sharing information with us and good luck with your future projects.
