The link below is to an album of pics of a restored 1965 diesel Bullet listed for sale recently on Craigslist. As I recall the asking price was $6500. A bit salty I suppose, but a very nice restoration.
If you're not familiar with Picasa, after selecting the pic, click the magnifying glass in the upper right and then use the cursor to move the picture around.
http://tinyurl.com/5cygjq
1965 RE Diesel Bullet
- taildraggin
Diesel Enfield
A very nice original example of the indian conversion, the only part of it that might be from 1965 is perhaps the frame.
Check the number - it will be stamped on the headstock in a font with heavy serif's - should begin G2.... indicating the frame was made in the UK and shipped over in knock down form.
Front wheel and forks are the latest factory items with the disk brake conversion rather than the electra front end that has the removable axle.
The rear hub is the new type too - full width, '65 items have a half width hub and speedo drive.
basically a brand new bike built on a '65 frame - very cool.
The only part missing is the front sheet metal deflector that fits to the front engine mount and stops dirt being thrown at the regulator adjusters.
Cockney Bob
Diesel
Very nice the engine looks the same as Mine and the rest looks great of course as Dave says not much of it is 65 but if you can get awaay with it go for it.
Bob
Bob
- taildraggin
Cockney Bob
Filter
If you do buy it I bet the first thing you have to replace is that Fueo filter Not the air filter,
.Mine leajed like a sieve and nothing woyld stop it other than replacing it.
I think Dave had the same problem the spun aluminium keeps spinning.
Bob
Bob
1965 Bikes
Just so you know, in the UK you can legally replace the frame too.
The rules are you have to destroy the original.
Wow I wish that would be possible in Holland, I don't think you can legally replace the frame
Would be much better, make a strong frame out of modern steel instead of the stuff intended for urinals.
An ebay store 'export connection' sells these bike swit an india-greaves 10 hp engine. I recently did some tinkering with one of these bikes. the frame number was grinded away and made it to match the engine number.
The electric wiring was a mess...
the engine was sounding very nice, like it wasn't a direct-injection engine ..and started perfectly at temperature around zero.
Maybe due to the newness of the engine, it was quite calm in throttle response.
I guess after running in, an alternative air filter instead of the large iron mesh-and-oil filter might help..
