a little more progress made with my build. Engine and gearbox now mated with a heavy duty bmw clutch. Starter motor fitted but requires spacing. Have now cut the frame and am getting everything alligned trying bits on to ensure nothing fouls it, it needs a 110mm stretch. I am getting it welded professionally and will only tackle the smaller welding jobs myself (brackets etc). I am trying to source some quality frame steel tube 48mm with 4mm wall thickness for the upper frame piece and 34mm with 4mm wall thickness for the lower joins anyone any helpful contacts?
John from Dublin.
