Transmission question
Mark
Post by Mark »
I've never seen this, so I thought I would ask-
Has anyone ever cut up a motorcycle engine in a way you could utilize the transmission? Size would probably be an issue but just wondering if this may be an option on occasion.
For every hour in front of the computer you should spend three outside.
BoxerOtto
small motorcycle transmission
Post by BoxerOtto »
hi mark,this is boxerotto. if you look at my build , i indeed intended to use an old motorcycle tranny so i could utilize the wet clutch and five speeds,however some modificaton is nessesary. i would remove the crankshaft because it would no longer be a balanced unit with no rod and piston and replace it with a simply machined strait shaft and install another outboard bearing on the mag side where my input would drive. for my ratios to work i would have to double the engines 3600 rpm to the crank of the tranny using timing belt pulleys and a shorter cog belt.my doner tranny is from a 1982 kawasaki KDX 175 enduro bike. i may look at a 80 cc dirtbike tranny also because most have six speeds and is more compact. i don't know if it would be robust enough. the KDX tranny has good sized gears and bearings.also some modification to the cranshaft case area may be needed to allow tranny oil to flow to the former crank bearings. thats my thouhts on this any way, and don't know if anyones actullaly has one up and running.
cant seem to work this imaje shack thing at the moment. My honda uses a RD350 engine as a gearbox and clutch, works just fine and as the rd350 was 40hp copes no problem with the 23hp the Ruggerini 950 puts out. Six speed so it keeps your left foot busy, in sixth 1500 is 30mph and 3600 is 70mph.
