Hi Lex,
Smart choice to order from Combidrive, they have been faultless with me as far as advice and after sales service. Im sure you wont be disappointed.
Just for the benefit of others who are doing CVT builds I'd like to reiterate a couple of points that might save some time in the long run.
The figure you have been quoted for engagement is a nominal figure, presumably for an optimum set-up.
Get the final drive ratio too tall and more force is required to turn the wheel. This means more friction is required to over come belt slip. More friction means more revs and before you know it your clutching is engaging far higher than the manufacturer states.
Likewise if the belt is too slack, more revs are required to take up this slack before engagement, then as the belt has had to travel further up the cone, it is trying to engage at ratio higher than is necessary. Again higher ratios require more force and suddenly your quoted 1600rpm figure can easily become 2200rpm.
Apologies if Im repeating earlier stuff, I just want others to understand the importance of getting the basic set up right. Whilst I knew the theory of how they worked, I only really understood it when I started playing about with it.
Look forward to hearing how you get on, good luck
Mark
