my criteria
1 Crap bike.
2 stinking of diesel.
3 horrible to look at.
4 cheep.
5 cold morning big cloud of smoke lots of Knocking wake up neighbours.
6 going have sidecar for the dog to go in and i can run on car tyres too.
in the beginning there was a MK5 ford fiesta 1.8 Turbo diesel for £60. ok its got some flaws fly by wire pump cant be that hard. spent few hrs working out the wiring from the pump to the ecu all done 2 wires left to work out sh*t the dreaded PATS.OK i worked out that the ecu controled the earths to engine control relay so forget about the pats i can just switch it on cant i ? so i wired it all up big smiles cocky grin robinsons bottle of fuel cranked her up battery was a bit flat not starting. Bugger charged battery made a suitable fuel tank more big smiles and a cocky grin treid another time not havin it. Ok crack of an injector try again got fuel yeah f%$k the PATS but it still wont fuckin start. Maybe heater plugs bit of wire will do the trick straight to the battery no it still wont fuckin start. went home looked up fuel pump not happy turns out that it will be coded and i dont want all the extra sh*t for the PATS need enough wiring as it is anyway. So i got to get a older pump
I proberbaly wont get to do anymore for a few weeks due to work but hopefully i will get the pump on and get it running. i may be able to flog the other pump and bits on get a bit of cash back for the build. but at least it will be a start of a slow build.
