I thought that fitting the engine in the frame was going to be relatively straightforward.
Think again, although, in the whole scale of things, it’s probably not that much of a problem.
Because the BMW engine lies flat on its side, the crankshaft and therefore the gearbox input shaft is also over to one side. In the BMW there are various idler gears but in the whole scale of things that makes no difference because the original BMW engine has gone and we are stuck with what we have.
20160126_234418 Anyway, because the gearbox input shaft is not central in the gearbox and the crankshaft is central in the engine it means that the engine is offset to the right as you sit on the bike (why did I never think of this before... Stupid man)
So the upshot is that the engine which is now bolt upright fouls the top right hand (as you sit on the bike) frame tube. You can see it on the left in this picture.
20160126_234508I was going to have to remake the mounting here anyway but didn’t want to really do any tube manipulation. Here is another view of the offending tube which, in this photograph would need bending towards you where it crosses the top frame rail and then bending away from you a little further down.
20160126_234443 I could slant the engine over slightly towards the left-hand side (as you sit on the bike) which is to the right in the pictures of the front of the engine that would probably balance the whole thing got better and give me a little more clearance around the frame tube which is fouling. It would still need modification but I would probably get away with not bending it. It would also mean that the gap between the engine block and the other side engine mounting would not be quite as big. I reckon that about 5° would be about what it needs although 5° is quite noticeable. If you look at this photograph, it would be moving the engine around the axis of the crankshaft a few degrees and to a position more central between the two short front frame down tubes.
20160126_234508It would mean me remaking the gearbox adapter however which is about three quarters finished. However apart from time, the cost is only another 50 quid for some plates.
The potential problem with sloping the engine over is that it was designed to run at an angle of 45° and it’s already moved from that angle to vertical and if I move it more, it’s actually going the opposite way. I guess that it’s easy enough to cut the triangular gussets out and remake them and to re-bend the offending frame tube.
I’m just wondering, which alternative all the experts on here would themselves choose.
Although psychologically, having wait a little more central makes more sense, in everyday riding it makes no difference because, after all, Lambretta never had a problem with it and nor did (and their situation was even worse) Vespa.
Thoughts?
