Following on from my further refining of Tim's old Superdream 850, I am now tackling the cooling system.
I have replaced the old gauge with a digital version of the same and went out for a ride today:
It hovers around 70-75 on 40mph roads. I can also feel that the thermostat is working correctly as when it gets to around 82, my seat gets warm.
As soon as you get it on a motorway or fast road (60+) the needle just keeps rising.
The red X is an Aux cooler plumbed into the header tank line (before thermostat)
The blue X is the main radiator. It has 2 large fans running constantly. My first thoughts where airflow. So I removed both the red side panels. No change.
In fact the reading went up to 104 and I had to slow down to 50 to get it come back down again.
I am stuck a bit now. I can only assume the 12v water pump doesn't flow quick enough. Maybe replacing it with a more powerful version will help?
