He has a opinion that Dnepr final drive reducer is a problematic unit (I agree with that) so bye bye to the shaft.
clutch is automatic and centrifugal, from some kind chinese scooter, no test drive yet so I don't know how that clutch will work
Correct so far. But the the driveshaft goes thru the drive shaft peg and with its ball shaped end into the hole of the gearbox output shaft. Or was it the other way ruond, I don't have the parts here. Could be that the gearbos output shas a ball shaped end and the drive shaft has the hole. In any case, the is a centering device there. But, I saw also parts where it was cut off, by somebody who did not understand why its there.Tetronator wrote:Hmm, then I'm confused as to where the problem lies exactly.![]()
This is the gearbox output;
The rubber damper/flexible coupling goes over the 2 pegs;
The the driveshaft pegs go into the remaining 2 holes.
And I tougth the vibrations stem from the rubber damper/flexible coupling.
I saw Universal joints which were not realy in line. Did you check this?Tetronator wrote:This is the 'leaky seal oil drain hole' you talked about earlier I think.
I still do not know what causes the vibrations then... Imbalance in the driveshaft?
Hmm, I can see the pictures just fine. Anyone else have the same problem?bf109v7 wrote:I saw Universal joints which were not realy in line. Did you check this?Tetronator wrote:This is the 'leaky seal oil drain hole' you talked about earlier I think.
And I can see a picture adress only when I go on quote, it is not coming in your post. But I can not load any picture.
myural.com does not open
Alex
Acording to numuzmar, the shaft and rubber dampers cause a lot of vibrations due to having a huge imbalance which causes the gearbox/final drive to start leaking oil. The oil coming out of the final drive will leak onto the rear brakes and cause them to not work.numuzmar wrote:Dnepr shaft is one of sources of vibrations, rubber damper also commonly have huge dis balance, that causes leakage from gear box, and do I have to mention if you have a leakage from reducer you stay without rear brakes, hear me right, IMHO its good when you have bigger engine or you ride with sidecar, I say its not that bad and you can deal with that problems but its way simpler to deal with quality chain
Nice, doubt mine will produce as much. Put many miles on it yet?mark_in_manchester wrote:My Ural-Daihatsu 993 turbo works fine - 50+bhp (compared to ~33 stock on a good day), loads of torque, 90mph top speed and no gearbox / FD problems yet (though fitting the 3.2:1 modified bevel set was / is a big pain in the arse).
Does that work? Or is the filler plug lower than the breather hole? Otherwise the oil will still go into the drum, right?mark_in_manchester wrote: I added a bit of bent-over tube to the Ural FD filler plug as an additional breather, as the factory breather vents into the drum (!), albeit in a manner which is not 'supposed' to coat the shoes in oil. It seems to work. If you have a Dnepr FD the breather is under a plastic mushroom somewhere near the top and external, so this should also work fine.
I see, too much boost?mark_in_manchester wrote:>Nice, doubt mine will produce as much. Put many miles on it yet?
Probably 4-5000. Head gasket is gone at the moment and first I had to change the one on the car too, as being more in the family 'critical path'! Slowly looking like I might soon get time to do it.
Hmm, I cant seem to find the gears.mark_in_manchester wrote: >How was fitting the modified bevel set hard? Because I'd like to do the same, I heard it required some machining of the FD.
3.2:1 sets used to be cheap from Oldtimer Garage in Poland. Then they were not available - now they are again, but made somewhere expensive I think! The pinion is BIG - too big to go through the hole in the casing it has to fit through. You have to file away the shoulder that the big double-row bearing which the pinion runs in, locates against. Expect to make shims until you get the backlash right between crown wheel and pinion - I'd not have been able to do it without a lathe. I put a post on here somewhere about doing it, in some detail I think - a few years back now.
I see, then I'd rather just plug the drum hole and go with your solution. Not having brakes is bad...mark_in_manchester wrote: >Does that work? Or is the filler plug lower than the breather hole? Otherwise the oil will still go into the drum, right?
You're just relieving (gas) pressure, so as to stop an oily mist filling the drum. If you follow the makers instructions and ONLY put enough oil in it to come up to the BOTTOM of the threads on the filler (oh - unlike Ural I think Dnepr give you the luxury of a dip stick!) then liquid oil should not reach the level of the breather, and lack of pressure should mean large oil seal holds oily mist out of brake drum. It seems to work fine for me, and I've run a variety of Ural bikes for about 15 years.
agree.. add a tube to it and plumb that to drip where you need it. Call it a self luber for your chain ?? If you decide to stick with shaft drive after all.. drip it on the CV joint/U Joint?mark_in_manchester wrote:I'd leave that hole open (your finger points to it in one of your pics) since if anything makes it past the seal, that gives it somewhere to go...
