2006 Honda Rebel, 10k miles. Terrible paint job but that will go away later on.
So far, the chassis has been stripped.
A Kubota OC95 is what I shall be using. Its pictured here with a KKK KP35 but its much too big for this engine so I will use a VZ21 with an intercooler.
I was able to track down a recoil start kit so I plan to delete the starter. That will cut 4lbs but it will also make fitting into the chassis much easier.
A small Lithium battery will be used for the glowplug and charge equalizing.
http://www.ballisticparts.com/product_i ... cts_id=424
One great thing about the Rebel is its simple harness, but I can clean it up even further.
As hinted by the wiring diagram, I plan to eventually add water/methanol injection using an air pressurized refillable aerosol can.
My only roadblock right now for that is finding a 5-15cc/min atomizing nozzle that works at 50-120psi. The best I can find is for 2000+psi pressure washers and misters.
