This is how it started out before we removed the old single-cylinder engine.
We cut out the front vertical supports so we could clearance check the engine.
So far it will sit at an 8 degree forward tilt for better clearance rear side.
Good news is both valve covers can be removed for service without pulling the engine! I might even be able to get the rear off without pulling the fuel tank.
Bad news is we will need a new CVT. The Comet 44C/44D is just too small for the engine and I believe without a doubt it won't handle the torque. We will swap it out for a Comet 94C/90D. That has a better ratio spread and a ribbed drive clutch over is available for even better torque capacity.
The intercooler idea is out. We couldn't find something small enough that will fit behind the forks and all the other ideas for the intercooler we currently have would either look ridiculous or need excessive tube lengths (such as mounting it in front of the forks or down low).
The turbo will easily fit above the engine and under the existing fuel tank without any modification.
Already had to helicoil a bolthole; one of the intake manifold bolts pulled the threads out with it.
There is still a depressingly large list of things to do, such as:
Rewire everything to get rid of the clusterfūk behind the headlight. Will probably do weather-pack connectors for corrosion resistance.
Cradle front support.
Figure out how we are going to control a throttle that has about 1/4" total movement and moves the opposite direction we need for cable control (maybe use a compounding lever?)
Install the turbo (oil lines, exhaust headers, intake connection)
Switch the front wheel for a disc brake version.
Mount the pannier cans.
The plan is to do a full, runnable build to get all the details sorted. After we make any necessary tweaks we will tear it down to the frame and get everything painted.
The jury is still out on if I will paint the engine or leave it "naked". I'm leaning to painting because touch-up will be easier and I have heard the "plated" items (like the starter and bolt heads) will corrode and turn fuzzy white.
