kubota 2cyl z482
bobsav
kubota 2cyl z482
Post by bobsav »
looking for info on crankshaft balancing on a Kubota 2 cyl z482.
Re: kubota 2cyl z482
Tell us more. Are you asking about original factory balancing? Following modifications? Higher RPM's? And is it true you only have 1 traffic light in the entire county?
bobsav
Post by bobsav »
pietenpol2002 wrote:Tell us more. Are you asking about original factory balancing? Following modifications? Higher RPM's? And is it true you only have 1 traffic light in the entire county?
have done major modification to engine. high lift cam, larger valves, ported head , stiffer valve springs, adding intercooled turbo, beefed up rocker supports, valve relief pockets cut into piston tops , carillo rods, dry sump engine(.stock,) this engine would turn at about 3600 rpm. with the governor. have removed the governor. am hoping to turn at about 4500 to 5000 rpm. these are externaly balanced cranks. flywheel and front pulley are counterweighted. was wondering about making it internaly balanced. balancing the flywheel and front pulley by themselves,and adding heavy metal to crank counter weights. diesels are a bit new to me. any info much thanks. and yes ,only one traffic light, and its just a blinking red , so you don't run thru the intersection at night, and we all complained about it.
Mouse
Post by Mouse »
Hi,
These are roust engines. Because I bought mine as a non runner I've rebuilt it a times and had to have the crank reground but I've not attempted to modify mine other than tweak up the governor a tad.
I'd have thought it's not much different to balancing a crank from a petrol engine other than maybe being a bit stockier and rotating a lot slower which should make things easier.
Have you contacted a company that has experience with crank modifications?
Any updates on how your engine is doing with all these modifications. Also on bike speeds and MPG etc.
Mouse
Post by Mouse »
For reference my STANDARD engine returns between 110mpg and 140mpg depending if you are smoothly chugging along at 50mph or at full throttle the whole time. Top speed is 70mpg and probably limited by available gear ratios in the BMW gearbox and shaft drive, however it will do a regular 67mph on the flat in still air.
I still have to rig up a tacho to check my max rpm
Thanks for the update Mouse. Great numbers to have.
