Good to see this topic is still alive and kicking, have missed a couple of posts so playing catchup now
> Darren
Thanks for the info. I'd be glad to get a hand on any injector electrical info I can so pointers appreciated.
I asked a couple of chip tuning companies but they are unable to help me with the standard Smart ECU. As Erik says, I don't think thats the road to go anymore and would probably end up using more time and money anyway.
You are definately right that there is more info for the VW engines, but the weight of them is what put me off the most. I can just about lift the engine I have now which I reckon means its 40 - 50kg or so and should work well in a bike. Time will tell if I live to regret the decision...
> Erik
I was considering converting the engine to dry sump so that 45 degrees would not matter and I could reduce the overall engine height. Having said that I may keep the original sump etc depending on how I decide to lay the whole lot out.
I am planning to use an Ultima transmission for my project. This is essentially a harley gearbox although this is 6 speed which should be useful. There is a nice calculator on the internet that I put the gear ratios into and this box should be just about right for the engine although another couple of teeth in the front primary sprocket would be useful.
This is similar to the EDIMO project although I will be using chain primary drive as I think it will be easier to setup and I was able to find a chain primary and clutch on ebay for a good price. So far I have the engine, gearbox and primary drive. Depending on layout I may have to fabricate a primary drive housing (which is oil tight) though I think this pain outweighs trying to align engine and transmission accurately enough for a belt drive. We will see...
ECU wise I am still considering making my own. I am thinking of a high speed PIC or Motorola cpu and whatever electronics are needed to cleanup the sensor signals and drive the injectors and rail pressure actuator. I write software for a living so can already imagine how the program would work although would need some dyno time to figure out the correct map probably. The big problem with this at the moment is trying to aquire electrical drive information for the -
- Common rail pressure actuator (far as I know it is 1khz squarewave with varied duty cycle, but what voltage??)
- Common Rail pressure sensor
- Injectors (believe these are high voltage peak and hold although would need current information and also injector flow map would be useful)
- MAP sensor (Could probably work this out with my compressor and a pressure guage but not sure what voltage it would be driven by and what pins)
I'm still looking for this info if anyone can help. So far I have some information but not all. I have a wiring diagram for the standard ECU though this does not give the above information obviously. I've also been looking at Bosch manuals although there are so many of them its hard to know which one if any would give the info.
Could be BSG solution would be a good way to go, but I don't think I can afford the application program as well as the ECU. Could be an option if some nice person could set the map on it for me???
Frame wise I will see once I have worked out engine and gearbox layout. I want a trailbike style of frame. I have a contact of a company here i Belfast that can fabricate a frame from scratch if necessary although a standard frame from another bike would save £££ and paperwork.
> Byrdman
Nice project you got there!
Neil
