first pictures of my project lister hardtail chop
reg hardlyrideables
Post by reg hardlyrideables »
picture of my engine verible speed3 cyl lister petter made in 1990-1991 i think
and the frame some slight mods needed but its long enuff to fit any engine in :)
the builds going really slow as im still off work recovering from having my broken leg mended again
not sure weather to fit my big fat springers or a set of gsxr forks
with good front brakes
emmm decissions decissions
johnfireball
Post by johnfireball »
Hi, are you going to use the car type transmission as pictured. If you locked up the diff you could attatch a sprocket to the output. How will you change gear?
John.
reg hardlyrideables
yes i am going to put a sprocket on the driveshaft only thing with the final gbox ratio ive got to have a very large front sprocket bigger than rear changing gear is easy with a bit of bent bar and a shaped plate
Rick
Post by Rick »
What did that transaxle come from? I can see making something like THAT work..
johnfireball
Gearing
Did you know that if you lock up the non drive side output shaft that due to the way the diff works the shaft with the sprocket attatched will turn at double its normal speed. Gearing problem solved? I'm also interested to know what the gearbox is off.
John
What you have to do is weld the planete gears to the sun gear then is goes at the correct speed.
Sorry Jon I did not read the end of your message sometimes the web page opens up double size and I have to use the scroll bar to see all the message. You are correct what you say but how long the planete gears would last is anybodys guess, as they only move occasionally under normal opperation.
